RE: Skymaster L39 build
Hi George,
20 minutes is not bad. I have not started to work on my tank install yet. I might end up doing what you did.
Hard to tell from your pictures if your flap arm ended up not being perpendicular to the hinge line. After Alex commented that his was off also I would bet that they are all off. This is based on the fact that the flap servo mount is off. In my case I did not discover it until I attached the flap horn to the servo arm before I glued the flap horn into the flap.
I have a copy of SM's manual. I printed it off the computer when I started the build. It is not very helpful.
Thanks George,
Stan
