RE: Servo Play
Servos using a top cover plastic bering will wear rapidly with use and they will demonstrate a sloppy output shaft in time.
Not much you can do short of replacing the case's top cover and that is really not worth it with bottom line servo's.
A better choice is to use a servo with ball bering output shaft if the slop cannot be tolerated.
John
