RE: Servo Play
Put you finger on the output shaft/servo arm of the servo with the system powered up. Now wiggle the surface with your other hand, if you feel movement of the output bushing at all then that is your problem. Its a worn output bushing.
Thirty four flights in such an airplane is easily enough to show noticible wear with a plastc top bearing.
John
