RE: Servo Play
Hi!
Are you sure it's the servo???
Check the linkage! If it's the ailerons check the servo arm, aileron linkage , and where the linkage is glued to the ailerons.
...And most important! check so that you have long aileron linkage and as short as possible servo arm...this is the basic servo set-up rule!
