ORIGINAL: spaceworm
The Kalt KG 22 is what is now the Zenoah G23. I will see if i can find an article of when the G23 was first reviewed and where they referred to it as basically the Kalt. As i remember, the only difference was that the prop shaft length was different. Since the prop shaft is actually threaded into the crankshaft, like the K&Bs, changing its length is no big thing, only the thrreaded prop shaft rod and the prop hub need to be different. You indeed have made a good deal at $50 for both plane and engine, as long as both are servicable.
The Zenoah G23 is actually a Komatsu Zenoah engine, as is the Kalt branded version.
The model appears to be a rendition of the CAP 21, but whose rendition it is I do not know.
Ed Cregger
