RE: DC2/GT5/C5/FG/EVO/ELCON/CAD/BEETLE
DC: my man don't even both with the old 813 carb you have now..I am sure it is junk...possiable worn internals
worn throttle shaft holes...worn accl ball.. weak spring......Just for get it..Use a 688 stock carb with all new lines
klunker & new fuel tank....should solve your fuel problem..When you get your new 813 carb....silacone
the hole in the back..let set up and install the carb....There your back to running again......
I say your going to be taking that old 813 carb back off again ..and you will be flusted all over again.....
DC Man I am trying to help you here.......Slawhammer
