RE: DC2/GT5/C5/FG/EVO/ELCON/CAD/BEETLE
slaw yes im defo going to change lines & clunker...
moo/slaw here is the thing....
the line is drawing bubbles from the tank then to carb,i dont think its the carb at all (but i may be wrong) i cant understand where the bubbles are coming from,but now as you lads told me i think also i better change the lines and clunker/seal.....
the engine strip moo was kinda routine/curiousity really more than anything,i wanted to check it from head to toe,engine is like new inside as i use fg filter & outerwears prefilter..
its a complicated thing and i want to avoid spending on another carb if possible,i wouldnt bother even using stock carb on cad engine as it needs 813 for its porting and flow
