ORIGINAL: dtacmed
No0w its starting to make a little sense. I did set it up as if It was going to be 3 d capable at least as far as servo arms and throws. Obviously but not going negative I don't need the throw needed for 3D. Do you think I need to shorten these arms or just deal with the numbers as is?
Well, It depends on what you want to do. If you really want to keep the non-3D set-up, you should shorten the arms, and re-adjust the linkages. I do recommend that you program some negative on your set-up at least -4 degrees. You WILL thank me the day that a gust of wind catches you off guard. Start at -4 a 0% on the pitch curve, then program about 5 to 6 degrees at 50% and finally 10 degrees at 100%. This will take advantage of the full resolution of your radio. Also make sure that your servo travel is set to 100%.
Rafael
