RE: Alpha 40 Prop/Glow plug suggestions
I use an 11x6 (I believe) Master Airscrew Windsor on mine and it rips up the sky for a trainer. I run mine bare prop with just the nut, no backplate or spinner. I have a two bladed starter spinner cup instead of the standard but you could just turn your existing cup around if you want to run bare prop.
You could use an A3 plug this time of year as they run a little hotter.I just left the factory EVO plug in it and I richen the high speedit 1-2 clicks for the colder weather.
