ORIGINAL: rebuilder
ORIGINAL: srt10
ORIGINAL: rebuilder
If you are referring to mine, its probably 30ish...........
wow 30ish on 6s?
sounds like something is not right..
That is an estimation from eyeing it..hence the ''ish'' part on the end..maybe upper 30's, but this is speculation til i gps it...its really not even debatable til then since its simply an estimate..and i'm not entering it in a SAW event, its a big 45'' Dumas, a pleasure cruiser...Plus, if i had said it went 50, then the ''its cant be that fast'' would have started, i dont inflate speeds, it just does what it does.
your pulling some big rpm numbers on a big hull (the rpm you have listed would be a SAW setup) and your getting 30ish? [:-]
with the proper motor (big NEU-10s, 12s) spinning that kind of rpm would be pushing 70s IMO
