RCU Forums - View Single Post - REVISED 2-speed shaft drag chassis
Old 01-04-2010 | 06:40 PM
thunder9000
Default RE: REVISED 2-speed shaft drag chassis
ORIGINAL: Brent Davis
Good to see you got your engine back. You have actually a better modded V-15 that what B&E runs. I know as Rick found some more HP in the crank timing and did the same to mine.
You won't have a power problem getting the ET's you want. You just gotta know how to drive that beast.
The pawl clutch is one that has mostly a single steel arm that swings out to grab a pin to turn second gear. Our clutch style as you see your own, spreads outward to grab the hub and turn second gear.
This is a custom 2 finger pawl system.
Make sure you keep me posted with your car and engines too.
are you able to adjust the spring tension on this clutch changer? looks good keep the pics coming.
