RE: Top Flite Taurus Build
OK, we're back at it.
I'm happy to say that the pre-shaped leading and trailing edges are now warp free and usable. With the spars made and tips laminated, we can start building the stab. First up is to cut the L/E to size for later use. Next, using a long metal rule, place it along the T/E to ensure a straight line, I use T-pins to hold it in place. I have several steel machinist blocks that I use a lot during construction, they make alignment really easy as you'll see. Being the shaped L/E & T/E don't have a flat surface, I used the blocks along their inside edges to make sure they're vertical. The metal blocks are placed against the metal rule and again, T-pins keep the blocks in place.
More to come....
FB
