RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 01-04-2010 | 10:39 PM
  #1523
bcchi
Default RE: NEW DLE30!
ORIGINAL: MKnutson
Just recieved the single bolt hub adapter from BCCHI, it's a quality unit! The only issue I had installing it was I had to modify an old 1/2'' socket to install the new retainer nut under the adapter. The socket needs to be a very thin wall to fit inside the hub. NO more drilling props full of holes. This works awsome!
Thanks, Bill (BCCHI).
Mark
Mark you can cut off the prop stud that comes on the DL 30 and just use the hex part for the retainer nut. It is smaller then the nut we supply.I can not find 8MM nuts with this size hex size.
BCCHI
