RCU Forums - View Single Post - kb45 setup
Thread: kb45 setup
Old 01-05-2010 | 12:20 AM
  #51
rebuilder's Avatar
rebuilder
Default RE: kb45 setup
ORIGINAL: srt10
ORIGINAL: rebuilder
ORIGINAL: srt10
ORIGINAL: rebuilder
ORIGINAL: srt10
ORIGINAL: rebuilder
If you are referring to mine, its probably 30ish...........
wow 30ish on 6s?
sounds like something is not right..
That is an estimation from eyeing it..hence the ''ish'' part on the end..maybe upper 30's, but this is speculation til i gps it...its really not even debatable til then since its simply an estimate..and i'm not entering it in a SAW event, its a big 45'' Dumas, a pleasure cruiser...Plus, if i had said it went 50, then the ''its cant be that fast'' would have started, i dont inflate speeds, it just does what it does.
your pulling some big rpm numbers on a big hull (the rpm you have listed would be a SAW setup) and your getting 30ish? [:-]
with the proper motor (big NEU-10s, 12s) spinning that kind of rpm would be pushing 70s IMO
Its an ''estimate''...............maybe im not a good ''estimator'' of speed while sitting on a dock............plus, like i said.............i run my boats way on the safe side..............smaller props and very cool temps.........seldom do my boats get over 110* on motor or esc...........and then it goes however fast it goes......... somewhere between 25-50. I can be sure that estimate is correct.
What? Now your saying 25-50mph????
Ohh boy, I realy don't care how fast your boat is...
All my boats run low 40s to mid 60s and all verified by gps
all low kv motors and good volts = winning combos that last
You were making an assumption of a "problem" based on my estimate of speed to another person...............you said something was wrong if its 30ish.............geez, i was replying to OSU's question and you jumped in with your "somethings wrong" comment, i didnt pm you to tell you the speed out of the blue......once again, based on an off the cuff guess of speed for the guy. And yes, now im saying between 25-50 to be certain my estimate is correct for you to critique me with. I'm not "certain of 30ish" but im certain of my range, which includes 25,26,27,28 etc. pick one. And i do run low kv motors with high volts as im sure you have read...so i guess i have "winning combos that last" also. Why would you volunteer the speeds of your boats, no one asked...........do you think i care any more than you? Got any vids of your Fast boats?
