RE: Walkera WK-2801 8ch Multifunctional Transmitter Review
On the WK2801E, I found that if you set-up the Hot Keys for funtions only available in 2801 mode, then go to 2401 compatible mode the Hot Keys still access to 2801-only functions, without having to go back to 2801 mode. I have my Hot Keys set-up for TRVADJ, DR&EXP and REVERS. I can quickly access these function screens while in 2401 mode via the Hot Keys, without having to go thru the stick menu and return to 2801 mode. Only certain functions are allowed to be set as Hot Keys....
Any one else using this shortcut?? Ted
