RE: How to drill straight for control horns
Right!
And that's the problem... that you need to drill perpendicular to the surface chord line, which is at an angle to the surface itself.
A drill press and a jig makes this much easier but it is a lot to deal with for a small hole.
I end up using a small finger drill, will looking at the control surface from the side, edge-on.
