RE: Ys 110's First start
The prop should be OK on the 1.10S on 20% nitro, but what you really want to do is put a tach on the engine and make sure you are in the 8900-9500 RPM range. If the 15X10 is making the engine turn lower that 8900 RPM then a 15X8 might be in order.
