RCU Forums - View Single Post - Does this sound right ?
Old 01-06-2010 | 08:21 AM
dtacmed
Default RE: Does this sound right ?
I was going to shorten the servo arms as mentioned above however with the Align servos moving in the balls looked as if they might bind. I did re-adjust everything and dropped all the servo arms down 1 spline. Now my pitch settings run from 0 - 50 %. Getting closer. As stated earlier I'm set up for normal scale flight only with low stick now being -2 @ 0% and high stick being +11 @ 48% I guess these numbers sound a little more "normal"
