RCU Forums - View Single Post - Engine suggestions
Old 01-06-2010 | 10:15 AM
Arjit
Default RE: Engine suggestions
Hey!
Thanks a lot..
I did consider the electric system. However, the problem was the weight of the entire system.
The system that I would be adding as the payload would be atleast 7 lbs.. and whatever electric configurations I could come up with were a bit on the heavy side.
The flight time that I am targeting is around 30 mins.
I felt that the AXi 5330/F3A is best suited for the purpose. However, the batteries proved to be a bit too heavy.
Can you suggest an alternative arrangement?
Also, would G20 be powerful enough for this system?
<br type="_moz" />
