ORIGINAL: Gungadin
Great job there Bob ! Looks like you added down & right thrust, no ?
The motor box has 1 deg down and 3-1/2 deg (!) right built in... A LOT! I left the 1 deg down but had to reduce the right to about 2-1/2 deg to get the soft mount to fit on the motor box and have the prop bolt exit in the middle, and even then it juuuuuusst fit. Later maybe I will have to do a throttle-rudder mix, but not much option. Might end up needing none, who knows?
Probaly not an issue at all when you hard mount.
