ORIGINAL: MTK
Bob,
What I do is bend the header to fit. You'd need a vice, a berzomatic and a piece of aluminum that you can drill and tap. The idea is to secure the header to the plate and the plate to the vice. Then gently heat the aluminum tube at the straight section and apply appropriate pressure. It's a five minute job
Matt
Just looked at Home Depot website and they have standard, pencil and micro torch heads, propane and butane. I'm assuming standard torch head w/propane?????
