RE: RE:
Sorry Pandi but the Orange County Chopper pipes have to go. You don't have a choice in the matter. I drilled out your spinner back plate to accept the roll pins in the prop hub. I also ground down the pins so they don't dig into your prop.
That's pretty much it... I'm going to take everything back apart and put a coat of epoxy on the 1/4" plywood shims and sub firewall I previously made to fuel proof the wood. As soon as the epoxy drys I will put everything back together and that's that.
Like they said in the "GoodFellas"... I will take care of that other "thing" too.
