RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 01-07-2010 | 12:03 AM
  #269
NJRCFLYER2
My Feedback: (42)
Default RE: SAP 180 (Syssa Performance)
The idea is that - in combination with the tuned pipe and the appropriate prop - it helps reduce noise quite a bit.
Alsp, you get less consumption from the batteries each flight, so you can use smaller capacity batteries. You get less current consumption because the airframe is doing a whole lot less shaking, so there is much less work for your servos to do to keep the control surfaces from shaking around. Finally, the airplane and everything in it lasts longer, since they are not getting beat up. Soft mounts pay for themselves in many ways.
