RE: how to fiberglass
I've successfully used a heatgun to thin 30 min epoxy when glassing a wing center section. I was assume this is slightly more convenient than the hot water method.
Also, no sure why you think thin CA is worthless. Except for the potential for fumes and the potential of gluing yourself, it's a great tool when used correctly, i.e. wicking it onto tight fitting joints.
