You could check out C-ARFSpark. Not the lines on an electric but cheaper. Habu would probably be a good choice - gets a lot more expensive when you go composite material.
www.tamjets.com Tam has a lot of electric stuff - Ihad his 1:12th F-16, flew great, only sold it to help buy another motor. The truth is - with a composite electric - by the time you get u/c, motor, batteries, etc, you could be into a boomer nano with a small turbine. Recommend a Habu to get your feet wet.
