ORIGINAL: Stoeptegel HI, looks like a killer radio. One question though, is the EPA actually limiting the servo throw? i.e. does the transmitter allow the servo go beyond the EPA when applying full flaps and aileron input at the same time on flaperons and thus go beyond the set EPA? Or is the EPA limiting and does not allow to sum different mix inputs? (if you know what i mean...)
No electronic means presently possible of governing maximum servo travel on all mixes known in any TX apart from Swash/Cyclic on some top end TX. However, refer to:
<u><font color="#00265e">Aurora A9 - Heli Swash Ring</font></u> to be included in a future Firmware Update.
<span style="font-size: smaller">- can apply to Mode 2 only.
</span>
Models should always be set up mechanically correct so EPA, ATV etc are kept to a minimum. Never rely solely on any type of electronic trim to fix as there are many different servos with differing fixed stops. Listen to servo and back off if any binding is heard.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
