RE: Metal Finish Tutorial
Gary, very cool. I tried the HOK stuff - not easy to do and pretty pricey.
Regarding application of the silver, you say that you cannot come back to an area that has already been sprayed. When spraying a long fuse, does the last lengthwise pass blend OK with the first lengthwise pass as you work your way around the fuse to your original starting point?
