RCU Forums - View Single Post - DL-100 throttle down issue
Old 01-08-2010 | 12:15 PM
captinjohn
Default RE: DL-100 throttle down issue
Get the engine warmed up and hold wide open and adjust for top rpm (turning Hi needle in) and then richen the setting just to the point where RPM,s drop a little...verry little. Then go back and set the Idle mixture for smooth running but not so lean it stumbles on throttle up. See what that does. Capt,n
