RCU Forums - View Single Post - power differences between maggie and cdi
Old 01-08-2010 | 02:28 PM
Flathead
Default RE: power differences between maggie and cdi
Some engines lose the ability to idle at lower speeds without the flywheel. I believe it may because of balance. You may want to check out the idle before you cut up any parts. I have no experience with a 25 cc RYOBI, but some of the earlier 31 cc engines are next to inpossible to balance if all the flywheel is removed. Practice makes perfect! I THINK. Flathead
