RE: Noob question
Most 4 strokes come with the second nut. If you run one lean, there's a really good chance it will spit the prop off. The second nut helps a lot. The protrusion extends into the first nut and gets squeezed tight onto the prop shaft, hopefully locking it in place. They still spit the prop occasionally. Don't stand in front of it while running.
