RE: Kero start
Alain,
Your question was posted on the 15 December, about the time everyone focuses on the holidays...
And since you "Know" what happened in England...you should be a bit more receptive to what we here at Wren have had to deal with.
To answer your question. YES...the 160 can be retrofitted to kero start. The combustion chamber and outer case must be replaced due to the relocation of the igniter. Also the kero version will use the Pro Jet ecu. I'll be speaking to Mike this evening and post you a turn around time for the conversion.
