RCU Forums - View Single Post - Robart air up/spring down retracts won't lock down
Old 01-10-2010 | 09:35 AM
airega1's Avatar
airega1
My Feedback: (204)
Default RE: Robart air up/spring down retracts won't lock down
Ralph! DO NOT PUT OIL INSIDE THE AIR CYLINDER! , it will swell the o-rings and you will have bigger problems. Try removing the air cylinder and stretch the coil for more pressure. There probably will be enough lube of a safe nature already inside, a wax free oil type must be used, like refrigeration oil, but use very little.
