RE: Scratch Built Twin
Hi!
Looks very good to me!
One thing though...You should have mounted the engines side ways! That way you would have obtained a more correct tank to engine placement. -You know the tank rule...!? As it looks now the carbs sit a little high!
Also ...Do use a Uni-flow set-up with two clunks! Engines work slightly better that way!
