ORIGINAL: jd391 Yes that works great, but is there a way to add flapperons to the mix.
Thanks again Jim D
Please advise exactly whatset up is required.
Read "2AILE & 2FLAP" as being one aileron and one flap servo per wing which usually means the outer two servos are ailerons and the inner two are flaps which canalter position - positive <> negative.
Flapperons refer to one aileron per wing functioning as both ailerons on J1 and flaps (slider on Aurora/Optic 6. or on a rotary knob TX such as Eclipse)
Perhaps flaps mixed with ailerons so each combined surface is also an aileron?
1. Enter settings > Model> P.Mixes>Aileron-Flap1>select> enter %rate required for left & Right movement.
2. Enter settings > Model> P.Mixes>Aileron-Flap2>select> enter %rate required for left & Right movement.
(each flap servo, asdisplayed by numbers on screen,requires own P.Mix)
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
