RE: Extreme Flight RC Yak 54 - 74 inch!
Well guys its all done there is really no need to add pictures but I will I suppose, I haven't put the new cowl on yet because I'm still waiting for it but other than that all the servos are done and everything is installed. I'm also going to order up some props from vess for the mld 28. To help the adjustment the c.g I moved the engine forward because it was contacting the bottom of the engine box and added a tru turn spinner and put all the batteries on the engine box. I'll let you guys know how the maiden goes but it probably won't happen till the spring. Also I canceled the idea of the a123's and just went with two 1500mah lipos that go through a smartfly sport reg and then off to the receiver.
