RE: Sebart Wind S Pro
I just hope that there is a better and more elegant design for mounting the side force generators. I have a Wind 110 and decided to put the SFGs; it was a pain in the ass to get it lined up right. you just have to eye ball it. I had to hold the wings in front of a very bright light and then line up the SFG with the right rib and then glue it. Not to mention the hole that you have to drill on the leading edge. To protect the finish I did put a clear scotch tape over the wing and then glue the pieces on to the tape. In my case the pieces werewarped so I decided to remove it.
It is a shame for a bit pricey plane they have not marked the exact precise location for the SFG. They should make it removable like the ones in Passport.
Any ideas if it is the same deal with the new 2m Wind Pro?
thanks in advance.
