ORIGINAL: geeter
did anyone try puting thew motor in the front of a funjet? can't get mine to launch at all as a pusher. just dives to the ground and rolls over. tried it three times and no luck but it;s still flyable. it has a 2700 kv eflight and a 6x4 prop.................RON
Once you master the technique it is no problem, we always got someone else to lauch at the start. You were always taught to launch a model slightly down, not so with the funjet you can easily lauch at 30 deg up.
This is what I do now when on my own, I have a mix setup on my transmitter (I use the gear switch) that puts both ailerons up (up elevator) about 5mm, this aids the launch and I just throw it ! soon as it is airbourne I flick off the switch
