RE: Some Questions
The tank being too high is the first clue to flooding. Most the people I know fly for about 10 minutes and call that a flight, some a bit more, some a bit less. You haven't said what type of pack, what voltage or what mAh the pack is. What type of servos and how many are in the plane? With a 4.8v 2400 mAh pack with five servos, I run both digital and analog depending on the plane, I get about 5 flights out of the pack on average, sometimes 6 sometimes only 4 depending on how I am flying the plane. I check my batteries before each flight with a volt meter and when they are getting close to there rated voltage then I use a field charger and top them back up. How long just depends on too many things to give a straight answer.
