ORIGINAL: Glacier Girl
It sticks out of the side of the case that doesn't turn, as the other end is tapped for a bolt on prop adapter, so no use for the shaft to stick out since the whole case/bell end spins.
That bolt on prop adapter was junk. Moved the shaft to the other side and used a Tru Turn instead.
