RCU Forums - View Single Post - Exceed-RC Raptor G2 Keeps Spining
Old 01-11-2010 | 11:03 PM
  #49
yadac123
Default RE: Exceed-RC Raptor G2 Keeps Spining
Yes stripped please replace part #26. Or your belt tension is not enough and the belt is slipping. loose up the 4 screws that locks the boom into the frame and pull it back and then tighten up 4 screws again and see if that helps.
Tail rotor servo connects to the gyro so I recommend you by pass it and connect directly into receiver 4th channel and try it out.
Andy
ORIGINAL: Dnutz
Andy,
When i turn my main rotor clockwise with my left hand (with mild force) and keep my right hand on the tail rotor, it clicks. Does that mean it is stripped? I mean it feels like it is locked, but when i apply mild to medium force it slips..please help because my Raptor G2 spins counter clockwise out of control before i hover. I disconnected the motor and set the DIP switches to factory (2,4,8) and to the ones you mentioned later in this posting (2,4,6,7)....but i get no response from the tail rotor (servo). At first it was glitchy, now it doesn't work at all! Help!
David
