ORIGINAL: cchariandy
I may be jumping ahead of the build a little but I didnt see it in Chads build either...how do you locate the stab ajuster pin with the adjuster already secured in place? Is the foam cutting so precise that you can just glue the adjuster plates in place and it will be aligned with the pin?
Colin.
Pretty much yes!
The plates that you glue into the stab halves are a real snug fit, well they were on my ZN Twister, also the screw holes to fix the adjusters onto the plates are pre-drilled. On the fuse, the hole points are pre-marked on the sides along with the joining tube markings, simples...........................
Isaac,
have you decided on the colour scheme for the Xigris yet or are you going the same as the Osmose?
Regards,
Andy.
