ORIGINAL: jd391 Hi Alan I am trying to emulate a full scale Beaver where the flaps and flapperons work in conjunction with each other. The flaps are on a three position switch with servos slowed to three seconds with the last position being full flap. It is this last position where I want the ailerons to drop to flapperon position just like the real deal. I'm sure it's possible with this TX but I'm not sure I'm smart enough to figure out the mix. I do appreciate your time Thanks Jim D
Aurora A9 - Set up Flaps for 2Aile & 2Flap with Flapperon for Scale Beaver.
Refer to attached pictorial guide added 17Jan09 or:</p>
Select "[Model Type]"> "WingType" > "2AILE+2FLAP" >"Set">[Tail Type] "Normal" . > "Set" > [Engine Type] > [Single Engine] > "Set" > [Retracts] Y/N >"Set" .[Airbrake] Y/N > "Set"[Fuel Mixture] > Y/N > [Channel Function] >
Ch1 & Ch5 = Aile: J1 & J1 (Stick one)
Ch6 = Flap : LS (highlight LS) > "SEL" > amend to "E"
Ch7 = FLP2: LS (highlight LS) > "SEL" > amend to "E"
[Sure? select Y/N]
Turn TX Off then Reboot and test above as basic settings
Do not use [AIL-FLP] under Settings>Model screen 1 as that does not provide for servo time setting.</p>
1. Enter settings > [FLT.COND] > [COND-2] > set. Select time "0" and adjust with up arrow to 3.0.
. Move switch to forward position and change OFF TO ON.</p>
2. Enter settings > Model> P.Mixes>FLAP > AILE >select. Move switch “E” to forward position.
. tap “Rate” and “+” to increase to 100% rate or as required for left & Right movement.
. Select switch E and change “ON” to the forward position return and Tap ”C” to change to “S”.</p>
3. Enter settings > Model> P.Mixes>FLP2 > AILE >select. Move switch “E” to forward position.
4. Enter settings > [S.Speed]
a) tap AILE to highlight L & R, use “+” to increase to 3.0 if slow speed required both going up and down or just “L” if slow down only.
b) tap AIL2 to highlight L & R, use “+” to increase to 3.0 if slow speed required both going up and down or just “L” if slow down only. Tap “C” to change to “S”.
c) Tap ½ to enter 2nd screen and select switch “E’. Tap “NORMAL” top left of screen to change to “[Cond-2]”</p>
5. Enter [Cond-2] and set Speed : 3.0</p>
Controls then operate as understood for Scale Beaver</p>
Double check EPA's to ensure full flap does not bind aileron servos.</p>
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links</p>
