ORIGINAL: cchariandy
I may be jumping ahead of the build a little but I didnt see it in Chads build either...how do you locate the stab ajuster pin with the adjuster already secured in place? Is the foam cutting so precise that you can just glue the adjuster plates in place and it will be aligned with the pin?
Colin.
Hi Colin,
It is no so important if the foam cutting is so precise or not, I will make the hole for adjuster pin in the fuselage according to the location of the adjuster plates in the stabs.
Best regards,
Isaac Najary
