Sounds great.I can deffinitelly use one more for that plane. Thank you very much . By the way one of my friends did buy that plane as well, blue version.
Greg
ORIGINAL: nitrostaff1
ok how about I send you a new battery to make it up?
John
Nitro Planes
ORIGINAL: alpiani
<div>Hi. I while ago I bought FMS Skyline 182 trainer along with other planes.
http://www.nitroplanes.com/4chrtffmssky.html order number yhst-17210252890263-102151. Before putting the plane together I checked all controls and everything looked fine. It was missing a few parts that others mentioned already, but I can live with out them. The problem was very unusual. When I put the plane together ailerons were moving same way, both up or both down. I thought Y connector was reversed, but it was fine. I took the plane to my local hobby shop for more help. It took them a while to figure it out as well. As I thought one of the servos was damaged. The mechanism inside of it was put wrong way. I had to buy a new server and a servo extension. Also from wheel steering arm wouldn’t hold the wheel tight.Those problems cost me 23$ and a few long hours of work. If it’s possible I’d like to be reimbursed in some way for the damaged parts.Other than that I really enjoy the plane, it flies great and it impressed a few of my rc friendswho’ll probably buy it as well.</div><div></div><div>Sincerely</div><div></div><div>Greg</div>
