RCU Forums - View Single Post - Exceed-RC Raptor G2 Keeps Spining
Old 01-13-2010 | 10:54 PM
  #54
Dnutz
Default RE: Exceed-RC Raptor G2 Keeps Spining
ok thanks andy i'll try that next. Once initialized, isn't the red LED light on the gyro supposed to be on (not blinking)? Mine blinks! I have the dip switches set to 2467....right? If it's blinking then it's not in HH mode am i correct? Could this be the problem? If i replace the gyro and the servo would this be a quick fix? Im finding out a lot about this stuff and am getting addicted! Your info is much appreciated!
David
ORIGINAL: yadac123
Its possible that your servo could be dead. When you by pass the gyro and connect to ch4, I want you to remove the servo arm from the servo and reposition the arm on the servo so that the arm and the servo case is 90 degree and perpendicular to each other. Does the servo still going only right? did you make sure your rudder trim is at the center?
Andy
ORIGINAL: Dnutz
ok so i loosened the boom from the frame, pulled it backand tightenedit back in....that fixed the slipping problem. But still cant get the rudder to work correctly. I have right rudder but no left. After the heli initializes and the tail rotor centers, i get no response from left rudder. I unplugged the tail rotor servo bypassing the gyro and plugged into #4 on the receiver and the same thing happens! no left! What can be going on?
