RCU Forums - View Single Post - Official F27 Stryker Part 8: Beginners to Custom Darkness
Old 01-14-2010 | 01:07 AM
  #961
Gryphon
Default RE: Official F27 Stryker Part 8: Beginners to Custom Darkness
customrcparts,
Gary that is great news about the mounts. Bunch of people want them.....for example see the posts above this one.
My brother might be game too, and my best friend is very interested.
Hopefully in a blink you will sell the first batch.
_____________________________________
Stryker Flyer,
Welcome to the Dark Side, MUhahahahahahaha.
Each of your setups below can make 1900-2000+++W in a Stryker....so you must have some big bbbbaaaallllllssss.
I'm fairly certain you have the 150A version of the logger especially due to the 16/35/1.5RC
As you can see both of my motors above are the COMBAT 5mm version too.....look closely and you will see that the number of turns (at end) is hand written.....fresh off of the press....LOL
My 1.5S should have said 1.5SC
Correction, in a Normal stock Stryker they will probably be propped for 2500++W with large 7" Sport props, but up to 3000W for low drag Stryker airframes that can run APC Pylon props.
They should make great Funjet motors too with not much heat generated at only 2500W (3000W possible for short duration).
Later,
Gryphon
