RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 01-14-2010 | 06:29 AM
  #752
avronaut
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: orcrest
Perhaps but I would have thought the conventional approach would have been simpler for the 72Mhz antenna.
If you look at this photo here there does appear to be a serious amount of wiring going to the base of the antenna connection. A lot for what would only need to be a dummy connection for the base of the 2.4GHz & 72MHz antennas.
http://www.flickr.com/photos/garethk...7622786379680/
Is there someone from Hitec who can confirm how the 72MHz antenna will be connected?
What's wrong?
Remove the 2.4GHz Modul. Unscrew the 2.4GHz antenna adapter the same way as a regluar antenna. Put the 72MHz MHz Modul in and screw the antenna in. That's it!
Uli
