RCU Forums - View Single Post - Noob question
Old 01-14-2010 | 08:04 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Noob question
An air leak can occur in several places, you need to check all of them. That would include the carb throttle barrel, carb to case, front bearing, shaft to inner case clearance, backplate; and for those with removable cylinder's, the cylinder to case. Some engines may also have screws stopping up unused pressure ports or openings to allow removal of piston wrist pin's, etc.
