ORIGINAL: madfreestyler
Hey All,
Ive just started putting the radio / services tray together but if i put the UAT in front of the main tank it is difficult to access the front wing retainer bolts with the tray in place, i notice many of the pics on here are simular. Was just wondering what people have done to workaround it?
Any pointers or pictures much appreciated.
Thanks in advance
HI i screwed some m6 bolts in to the tee nuts in the wings with the head cut off and a 60 deg tappered cross hole drill in it ( use center drill ) and fix some blocks in the fuz which these go into and the got a six m/m grub screw with a 60 deg point on it which screws into the block and into the tappered hole pulling the wings up no need to go into the fuz down the field just two small holes in the bottom to put the allen key in works great
http://www.rcuniverse.com/forum/m_59...39/key_/tm.htm
note the small allen key holes next to the screw for the hatch
