RCU Forums - View Single Post - Aurora 9 flaperon set up
Old 01-14-2010 | 09:33 PM
A.T.
Default RE: Aurora 9 flaperon set up
ORIGINAL: jd391 Alan I installed this mix three times and still have a problem with channel five.
If you go to monitor and watch chanel five when you hold hard right ailiron and switch E from 2nd to 3rd position you will see what I mean. Channel 5 moves in the delayed motion. Maybe I am missing something in the setup. Thanks Jim D
1. TXon - Select >Settings>[Channel] and check Ch1:AILE = J1, Ch2: Elev = J3, Ch3:Thro = J2, Ch4: Rudd= J4, Ch 5 Ail2 = J1, Ch6 = Flap = E, Ch 7:Flp2 = E. Ch8: Aux1 = Null, Ch9:Aux2 = Null. or amend as necessary.
2.With settings provided post #8,
J1 controls both Ailerons if plugged into Receiver slots 1 & 5.
"E" in forward position only also controls both ailerons,on which command both aileronsdroopslowly togetheras flaps, yet retain full aileron responses.
When "E" is flicked back to middle or rear position, the two ailerons immediately revert to normal aileron position without delay.
3. The two flap servos must be plugged into receiver channels 6 and 7 with both flaps up when "E" is rearward. The twoflapsdrop in two stages (as set) say 50 % when "E: is in middle position and Fully down when "E" is in forward positon withoutdelays.
<span style="font-size: smaller">(Above tested with standardHitec servos -used digitals may need to be reset to factory default.)
</span>
regards
Alan.
